Some minor UI complaints
Guys. Good things are happening and I feel more comfortable with each update, but…
…look at this image.
I can extend or shrink LOCKED toolbar (why, o why) but I can’t shrink the command bar so it is not showing the bit of previous line which I find visually annoying.
The white Main Window Title Bar is also annoying here. I would take it off, but then I have a problem with Rhino not returning to the maximum screen size. I have been reporting this before.
Locking affects position, not size. Seems the same in V7
I recall seeing this before, I think it had to do with localization. Can you send your _Systeminfo and a screencap of your Region settings in Windows?
Yes, this is on the list as RH-75189 Rhino title bar on windows 10 always looks inactive
What is the reason for locking the position but not the size? What are the benefits of it?
Not sure what the Region setting are so I’m giving all Sysinfo:
Rhino 8 SR0 2023-10-12 (Rhino 8 BETA, 8.0.23285.13303, Git hash:master @ 37cac91b70895fef5147a8ee715893cd6a0bdbfa)
License type: Commercial, build 2023-10-12
License details: Cloud Zoo
Expires on: 2023-11-26
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 16Gb)
.NET 7.0.0
Computer platform: LAPTOP - Plugged in [97% battery remaining]
Primary display and OpenGL: Radeon Pro 560X (AMD) Memory: 4GB, Driver date: 11-7-2022 (M-D-Y). OpenGL Ver: 4.6.14761 Compatibility Profile Context FireGL 21.30.44.17 30.0.13044.17006
> Integrated accelerated graphics device with 6 adapter port(s)
Primary OpenGL: Radeon Pro 560X (AMD) Memory: 4GB, Driver date: 11-7-2022 (M-D-Y). OpenGL Ver: 4.6.14761 Compatibility Profile Context FireGL 21.30.44.17 30.0.13044.17006
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60
Driver Date: 11-7-2022
Driver Version: 30.0.13044.17006
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Rhino 8 WIP\Plug-ins\Commands.rhp “Commands” 8.0.23285.13303
C:\Program Files\Rhino 8 WIP\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.0.23285.13303
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.0.23285.13303
C:\Program Files\Rhino 8 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 8 WIP\Plug-ins\MeshCommands.rhp “MeshCommands” 8.0.23285.13303
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.0.23285.13303
C:\Program Files\Rhino 8 WIP\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.0.23285.13303
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.0.23285.13303
C:\Program Files\Rhino 8 WIP\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.0.23285.13303
C:\Program Files\Rhino 8 WIP\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino 8 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 8 WIP\Plug-ins\SectionTools.rhp “SectionTools”
Your country/ region, and most importantly your Regional format. If you press the Windows button, and type Region, it should bring you to that page.
I suspect it is this bug: RH-72137 Bulgarian Regional format in Windows line spacing issue in Command Prompt
Most likely any regional format that uses a comma as decimal separator will have this issue
I guess the idea here is that you want the UI to stay positionally put, but still somewhat flexible. Maybe for toolbars it makes not much sense, but for panels like the properties panel it does.
I do agree that it is useful for panels but when it comes to toolbars it only leads to accidental dragging.
