I got the following errors while installing compute-rhino3d via pip.
May I ask:
- What is the causing these errors?
- How to solve this issue to install compute-rhino3d successfully?
C:\Users\joe>pip3 install compute-rhino3d
Collecting compute-rhino3d
Requirement already satisfied: requests in c:\users\joe\appdata\roaming\python\python36\site-packages (from compute-rhino3d) (2.22.0)
Collecting rhino3dm (from compute-rhino3d)
Using cached https://files.pythonhosted.org/packages/54/dd/fb06abed53eda3c888dec4dd22b13759d96719bd11d491070b457ad48b1e/rhino3dm-0.8.1.tar.gz
Requirement already satisfied: chardet<3.1.0,>=3.0.2 in c:\users\joe\appdata\roaming\python\python36\site-packages (from requests->compute-rhino3d) (3.0.4)
Requirement already satisfied: idna<2.9,>=2.5 in c:\users\joe\appdata\roaming\python\python36\site-packages (from requests->compute-rhino3d) (2.8)
Requirement already satisfied: certifi>=2017.4.17 in c:\users\joe\appdata\roaming\python\python36\site-packages (from requests->compute-rhino3d) (2019.9.11)
Requirement already satisfied: urllib3!=1.25.0,!=1.25.1,<1.26,>=1.21.1 in c:\users\joe\appdata\roaming\python\python36\site-packages (from requests->compute-rhino3d) (1.25.7)
Building wheels for collected packages: rhino3dm
Building wheel for rhino3dm (setup.py) … error
ERROR: Command errored out with exit status 1:
command: ‘c:\python\python36\python.exe’ -u -c ‘import sys, setuptools, tokenize; sys.argv[0] = ‘"’“‘C:\Users\joe\AppData\Local\Temp\pip-install-pt9w4kf1\rhino3dm\setup.py’”’“‘; file=’”‘“‘C:\Users\joe\AppData\Local\Temp\pip-install-pt9w4kf1\rhino3dm\setup.py’”’“';f=getattr(tokenize, '”‘“‘open’”’“‘, open)(file);code=f.read().replace(’”‘"’\r\n’“'”‘, ‘"’"’\n’“'”‘);f.close();exec(compile(code, file, ‘"’“‘exec’”’"‘))’ bdist_wheel -d ‘C:\Users\joe\AppData\Local\Temp\pip-wheel-90qqhep’ --python-tag cp36
cwd: C:\Users\joe\AppData\Local\Temp\pip-install-pt9w4kf1\rhino3dm
Complete output (63 lines):
c:\python\python36\lib\distutils\dist.py:261: UserWarning: Unknown distribution option: ‘long_description_content_type’
warnings.warn(msg)
running bdist_wheel
running build
running build_py
creating build
creating build\lib.win-amd64-3.6
creating build\lib.win-amd64-3.6\rhino3dm
copying src\rhino3dm_init.py → build\lib.win-amd64-3.6\rhino3dm
running egg_info
writing src\rhino3dm.egg-info\PKG-INFO
writing dependency_links to src\rhino3dm.egg-info\dependency_links.txt
writing top-level names to src\rhino3dm.egg-info\top_level.txt
reading manifest file ‘src\rhino3dm.egg-info\SOURCES.txt’
reading manifest template ‘MANIFEST.in’
warning: no files found matching ‘.pyd’ under directory ‘src\rhino3dm’
warning: no files found matching '.so’ under directory ‘src\rhino3dm’
writing manifest file ‘src\rhino3dm.egg-info\SOURCES.txt’
copying src\rhino3dm_init_.pyi → build\lib.win-amd64-3.6\rhino3dm
copying src\rhino3dm\py.typed → build\lib.win-amd64-3.6\rhino3dm
running build_ext
Traceback (most recent call last):
File “C:\Users\joe\AppData\Local\Temp\pip-install-pt9w4kf1\rhino3dm\setup.py”, line 32, in run
out = subprocess.check_output([‘cmake’, ‘–version’])
File “c:\python\python36\lib\subprocess.py”, line 336, in check_output
**kwargs).stdout
File “c:\python\python36\lib\subprocess.py”, line 403, in run
with Popen(popenargs, **kwargs) as process:
File “c:\python\python36\lib\subprocess.py”, line 709, in init
restore_signals, start_new_session)
File “c:\python\python36\lib\subprocess.py”, line 997, in execute_child
startupinfo)
FileNotFoundError: [WinError 2] The system cannot find the file specified
During handling of the above exception, another exception occurred:
File “”, line 1, in
File “C:\Users\joe\AppData\Local\Temp\pip-install-pt9w4kf1\rhino3dm\setup.py”, line 147, in
include_package_data=True
File "c:\python\python36\lib\site-packages\setuptools_init.py", line 129, in setup
return distutils.core.setup(**attrs)
File “c:\python\python36\lib\distutils\core.py”, line 148, in setup
dist.run_commands()
File “c:\python\python36\lib\distutils\dist.py”, line 955, in run_commands
self.run_command(cmd)
File “c:\python\python36\lib\distutils\dist.py”, line 974, in run_command
cmd_obj.run()
File “c:\python\python36\lib\site-packages\wheel\bdist_wheel.py”, line 188, in run
self.run_command(‘build’)
File “c:\python\python36\lib\distutils\cmd.py”, line 313, in run_command
self.distribution.run_command(command)
cmd_obj.run()
File “c:\python\python36\lib\distutils\command\build.py”, line 135, in run
self.run_command(cmd_name)
cmd_obj.run()
File “C:\Users\joe\AppData\Local\Temp\pip-install-pt9w4kf1\rhino3dm\setup.py”, line 36, in run
", ".join(e.name for e in self.extensions))
RuntimeError: CMake must be installed to build the following extensions: rhino3dm/rhino3dm
ERROR: Failed building wheel for rhino3dm
Running setup.py clean for rhino3dm
Failed to build rhino3dm
Installing collected packages: rhino3dm, compute-rhino3d
Running setup.py install for rhino3dm … error
command: ‘c:\python\python36\python.exe’ -u -c ‘import sys, setuptools, tokenize; sys.argv[0] = ‘"’“‘C:\Users\joe\AppData\Local\Temp\pip-install-pt9w4kf1\rhino3dm\setup.py’”’“‘; file=’”‘“‘C:\Users\joe\AppData\Local\Temp\pip-install-pt9w4kf1\rhino3dm\setup.py’”’“';f=getattr(tokenize, '”‘“‘open’”’“‘, open)(file);code=f.read().replace(’”‘"’\r\n’“'”‘, ‘"’"’\n’“'”‘);f.close();exec(compile(code, file, ‘"’“‘exec’”’"‘))’ install --record ‘C:\Users\joe\AppData\Local\Temp\pip-record-qwdemvcm\install-record.txt’ --single-version-externally-managed --compile
Complete output (65 lines):
warnings.warn(msg)
running install
running build
running build_py
creating build
running egg_info
warning: no files found matching '.pyd’ under directory ‘src\rhino3dm’
warning: no files found matching ‘*.so’ under directory ‘src\rhino3dm’
running build_ext
**kwargs).stdout
with Popen(*popenargs, **kwargs) as process:
File “c:\python\python36\lib\subprocess.py”, line 997, in _execute_child
startupinfo)
File "<string>", line 1, in <module>
File "C:\Users\joe\AppData\Local\Temp\pip-install-pt9w4kf1\rhino3dm\setup.py", line 147, in <module>
File "c:\python\python36\lib\site-packages\setuptools\__init__.py", line 129, in setup
File "c:\python\python36\lib\distutils\core.py", line 148, in setup
dist.run_commands()
File "c:\python\python36\lib\distutils\dist.py", line 955, in run_commands
File "c:\python\python36\lib\distutils\dist.py", line 974, in run_command
cmd_obj.run()
File "c:\python\python36\lib\site-packages\setuptools\command\install.py", line 61, in run
return orig.install.run(self)
File "c:\python\python36\lib\distutils\command\install.py", line 545, in run
self.run_command('build')
File "c:\python\python36\lib\distutils\cmd.py", line 313, in run_command
cmd_obj.run()
File "c:\python\python36\lib\distutils\command\build.py", line 135, in run
cmd_obj.run()
File "C:\Users\joe\AppData\Local\Temp\pip-install-pt9w4kf1\rhino3dm\setup.py", line 36, in run
RuntimeError: CMake must be installed to build the following extensions: rhino3dm/_rhino3dm
ERROR: Command errored out with exit status 1: ‘c:\python\python36\python.exe’ -u -c ‘import sys, setuptools, tokenize; sys.argv[0] = ‘"’“‘C:\Users\joe\AppData\Local\Temp\pip-install-pt9w4kf1\rhino3dm\setup.py’”’“‘; file=’”‘“‘C:\Users\joe\AppData\Local\Temp\pip-install-pt9w4kf1\rhino3dm\setup.py’”’“';f=getattr(tokenize, '”‘“‘open’”’“‘, open)(file);code=f.read().replace(’”‘"’\r\n’“'”‘, ‘"’"’\n’“'”‘);f.close();exec(compile(code, file, ‘"’“‘exec’”’"‘))’ install --record ‘C:\Users\joe\AppData\Local\Temp\pip-record-qwdemvcm\install-record.txt’ --single-version-externally-managed --compile Check the logs for full command output.
