so I try to run an external Rhino Script from within my own C# plug-in using the RhinoApp.RunScript method. Loading seems to be fine, but then I get the error message:
"Unable to load plug-in: plugin-in ID not found in registered plug-in-list"
and then the ID of the plug-in that Rhino can’t find in the list
I checked that by looking into it using the PluginManager, and indeed: the ID of the Command/Plug-In that I try to run from my code (which I have installed previously) is different to the one, the error message gives me.
But why is that? The path that I typed into the RunScript Command is correct. Does anyone know something about this issue? Can someone help me get this to run?
Thanks
