Hi @dale
There is any option to load Rhino Script file(.rvb) using C# API?
Rhino 5
-@Sarath
Hi @Sarath_Kithiyon,
The only thing you can do is script the _-LoadScript
and _-RunScript
commands using RhinoApp.RunScript
– Dale
Hi @dale,
I have tried _-LoadScript
and _-RunScript
commands, It shows cannot find script file,
Command: -LoadScript
Script file to load ( List ): <D:\Sample.rvb>
Cannot find script file <D:\Sample.rvb>
This seems to work:
var fname = "C:\\Dev\\Test.rvb";
var script = $"_-LoadScript \"{fname}\"";
RhinoApp.RunScript(script, false);
return Result.Success;
Make sure your command has the Rhino.Commands.Style.ScriptRunner
attribute.
– Dale
