Solution exception:ReflectionOnly loading is not supported
Rhino 8, latest version of MetaHopper. I’m attempting to use the Document Information component. I thought there might be an odd plugin conflict but I’ve removed nearly all plugins and restarted.
Any advice?
Hi there! I´m having the same issue, did you manage to solve it?
@Luis_Eduardo @closedcurve
Changing Rhino’s runtime from NetCore to NetFramework using SetDotNetRuntime command solved this issue for me
