Hello, i wanted to know if it is possible to create a solid or surface from random lines or points. Thank you in advance.
Solid.gh (4.3 KB)
So you want magic?
You can try the 3D Delaunay component from Mesh Edit plug-in.
It work!, i downloaded the plug-in and worked fine. Thank you so much
