Solid Difference Collapse. Help
Hi. I have closed breps and I have scaled version of it. I want to split the scaled version from the based ones. However, It collapses when I connect main ones.
I appreciate for your consideration.
scaling on the center of mass won’t generally work for almost any geometry, consider that in Rhino you can’t just enclose a volume inside another volume, there must be something that connects the two
by attaching your files with internalized geometries you’ll for sure get specific help
paraexa3.gh (91.0 KB)
parametrik.3dm (2.4 MB)
I appreciate for the commands. Actually, I was trying to make this connection. However, I could not make it. Thank you for your consideration.
is this the right file? :slight_smile:
Ah yes, I was working for 3 days on it. There is a miss part sorry. I will fix it and maybe ask it again later. Thank you for your consideration and attention. I appreciate it.
