Volume of a solid brep is negative
When will it happen as that?Is there a solution to solve this?
Maybe post the object here - it’s possible that the object is invalid, non-manifold or something else.
If you run Explode, RebuildEdges, then Join, does it join back up into a closed manifold solid?
Hi @duzhengjie1
That is a very well known topic, which solution can be easily found on the forum.
Regards
Hi @bbalbastre,
Sure that’s (still) an issue in non-uniform scaling in Grasshopper. But not in Rhino. Need to know where the OP is having the issue…
Regards
Jeremy
