Soft Move/ Edit for Meshes
Hi all,
I have a little problem, and I need your advice! Not sure if in Rhino or even Grasshopper have function like Soft Edit for meshes (which it same as soft edit for surface and curve, or just like a sculpting tool like Zbrush or blender), it’s like a move vertices with a radian falloff.
Thank you!
Denis
SoftMove | Rhino 3-D modeling
hi Martin,
Thanks for the advice ! not sure if this is the only way to solve the problem. I am looking for a more advanced way !
Appreciated,
Hi @Denis90
In Rhino the only thing that comes close is the SoftTransform command (not exactly like SoftMove) with subobject selection of edges or faces. This has been discussed many times and it seems that the general consensus is, that mesh modeling is better left to the programs that does it really well, Zbrush, Blender etc. There was someone working on a plugin at some point, but I’ve no idea if it’s still being worked on. And then there’s Clayoo, but the pricetag is hefty.
HTH, Jakob
Hi Jakob!
As Rhino is my main tool to do my job, so that’s why i just wanted to do all work inside Rhino, not jumping to another software. Thanks the recommendation to use Transform! Yeah it may be the best way for me, I think!
Cheers!
Denis
The SoftTransform tools have gotten a face lift in the Rhino 9 WIP. Please take a look and let us know how it works for you.
thank you so much,
