been working with snapshots a lot. somethings that are missing is setting the options that are available in the dialog when using the command line so we can’t macro out a full command with all the options. or in place of that, sticky settings that are saved across sessions.
also, this is nit picky, but for consistency sake, we can use the icon to save, but there is no ability to save a snapshot from the context menu. also maybe a menu item that is update instead of save so it bypasses the dialog. when i first started using them i kept expecting to see an update option. thanks.
We need to access specific Snapshot settings (selective properties) via Command Line so this can be used in scripts and macros. Currently I see only “Save” in command line but is saves ALL data which is hardly ever needed and bloats the file quickly.
How do I save Sun+Skylight+Environment data only via command line / script?
( hi @lars, making sure you are seeing this)
Thank you, looking forward to having this option. I was trying to automate the overall “Lighting” setup via scripts and save/restore all related Snapshots settings, but looks like we’ll need to wait with this.
Exposing the Snapshot settings directly to the scripting engine, apart from command line options, would be a nice development of this tool as well, not sure if this is on the to-do list.
