Hi everybody,
I have rhino 7.1 and the sanps doesn’t works if the x-ray view is on. I mean, they works but get only on external point of model, and if you try to pick point inside the model it don’t works or works only is you selected the element you wanna pick, in the last case could be a problem cause is you have selected some elements, before pick it with snaps to do another action, than this action will affect also the wrong element.
Does anyone has the same problem?
Hello - run the SnapToOccluded command and enable that, or change the setting in Options > Modeling Aids page.
Any luck?
Yea was SnapToOccluded command! thanks you so much!!!
