Smoothen trianglular mesh (how to?)
I generated a terrain mesh using the Rhino terrain plugin on my contour lines, and sometimes the result is too “stairs-like”, I would like to smoothies this result. Is there a command useful to get a better more “road-like”.
I tried the ‘smooth’ command but the result is still too close to the previous version.
The screenshot is from enscape visualisation.
BR,
you can select the triangles you want to affect, then use gumball and scale in the z axis (blue handle) to equalize them. where ever you place the gumball you can scale to that location. It will locate in the bounding box center of the selection unless you relocate it.
Try _quadremesh and you can use the contour lines as your guide curves.
Hi Felix - you could try SubDivide then Unweld at 0 degrees with ModifyNormals=Yes. Then, select some mesh points and Smooth in Z only.
