Small UI issues
i discovered two UI issues:
the colors on the preview options are messed up, clicking them they turn blue and don’t return anymore.
  1. Opening the GH script editor in full screen mode (two windows stitched together) also messes up the windows, this used to work, where opening the script editor would just open the window as usual inside / on top of GH
as always, let’s start with _SystemInfo :slight_smile:
Rhino 8 SR13 2024-10-29 (Rhino 8, 8.13.24303.13002, Git hash:master @ 26babd47cc5f584ddff42ed6aa46cbe40122c540)
License type: Educational, build 2024-10-29
License details: Cloud Zoo
Apple macOS Version 15.0.1 (Build 24A348) (Physical RAM: 16GB)
Mac Model Identifier: MacBookPro18,1
Language: en
.NET 7.0.0
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
  Apple M1 Pro
    Color LCD (2056 x 1329 @ 120.00Hz)
GPU Vendor: Apple
USB devices
  None
Bluetooth devices
  None
Third party kernel extensions
  None
Third party plugins
  /usr/lib/swift/libswift_Builtin_float.dylib
  /usr/lib/swift/libswift_errno.dylib
  /usr/lib/swift/libswift_math.dylib
  /usr/lib/swift/libswift_signal.dylib
  /usr/lib/swift/libswift_stdio.dylib
  /usr/lib/swift/libswift_time.dylib
  /usr/lib/swift/libswiftsys_time.dylib
  /usr/lib/swift/libswiftunistd.dylib
  /usr/lib/swift/libswiftDistributed.dylib
  /usr/lib/swift/libswiftObservation.dylib
  /usr/lib/swift/libswiftFileProvider.dylib
  /usr/lib/swift/libswiftMLCompute.dylib
  /Library/Frameworks/3DconnexionClient.framework/Versions/A/3DconnexionClient
  /usr/lib/usd/libusd_ms.dylib
  /usr/lib/swift/libswiftSpatial.dylib
  /usr/lib/swift/libswiftSynchronization.dylib
  /usr/lib/swift/libswiftNaturalLanguage.dylib
  /usr/lib/swift/libswiftGameplayKit.dylib
  /usr/lib/swift/libswiftSpriteKit.dylib
  /usr/lib/swift/libswiftWebKit.dylib
  /usr/lib/swift/libswiftGLKit.dylib
  /usr/lib/swift/libswiftMetalKit.dylib
  /usr/lib/swift/libswiftModelIO.dylib
  /usr/lib/swift/libswiftSceneKit.dylib
  /usr/lib/swift/libswiftVideoToolbox.dylib
  /usr/lib/swift/libswiftMapKit.dylib
  /Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework	"Renderer Development Kit"	8.13.24303.1002
  /Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp	"Commands"	8.13.24303.13002
  /Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp	"Snapshots"	8.13.24303.1002
  /Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp	"RhinoCodePlugin"	8.13.24303.13002
  /Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp	"RDK_EtoUI"	8.13.24303.13002
  /Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp	"MeshCommands"	8.13.24303.13002
  /Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp	"Rhino Render"	8.13.24303.13002
  /Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp	"RhinoCycles"	8.13.24303.13002
  /Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp	"SectionTools"	8.13.24303.1002
  /Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp	"Displacement"	8.13.24303.1002
  /Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp	"PanelingTools"	8.13.24303.1002
  /Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp	"IronPython"	8.13.24303.13002
  /Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp	"Grasshopper"	8.13.24303.13002
in RH 9 WIP it is the same
I could not reproduce this issue at my end, neither in 8.13, nor in the latest dujour :man_shrugging:
Which issue do you mean? I described two
here is the full screen issue. It used to work in previous versions…
hi @rudolf.neumerkel the issue you show with the windows I can repeat here,
thanks.
I just saw a post from @andheum having the same issue with the button states.
Since he is also on 15.0.1, I am guessing this has to do with it.
RH-84703 Button states don’t work well in Mac OS 15.0.1
RH-84704 UI issue with script editor in split screen mode
Perfect thanks!
RH-84703 is fixed in Rhino 8 Service Release 15
RH-84704 is fixed in Rhino BETA
