The C# option is not visible anymore - am I missing sth? I was experimenting with Python a bit and then it was not available anymore…
Rhino 8 SR13 2024-10-15 (Rhino 8, 8.13.24289.13002, Git hash:master @ 310800db9652d56ee534033b23cd53c62b5a1322)
License type: Educational, build 2024-10-15
License details: Cloud Zoo
Apple macOS Version 15.0.1 (Build 24A348) (Physical RAM: 16GB)
Rhino is running in Rosetta2 on Apple Silicon
Mac Model Identifier: MacBookPro18,1
Language: en
.NET 7.0.0
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M1 Pro
Color LCD (2056 x 1329 @ 120.00Hz)
LG Ultra HD (2560 x 1440 @ 60.00Hz)
GPU Vendor: Apple
USB devices
Generic: USB2.1 Hub
Generic: USB2.1 Hub
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswift_Builtin_float.dylib
/usr/lib/swift/libswift_errno.dylib
/usr/lib/swift/libswift_math.dylib
/usr/lib/swift/libswift_signal.dylib
/usr/lib/swift/libswift_stdio.dylib
/usr/lib/swift/libswift_time.dylib
/usr/lib/swift/libswiftsys_time.dylib
/usr/lib/swift/libswiftunistd.dylib
/usr/lib/swift/libswiftDistributed.dylib
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftMLCompute.dylib
/Library/Frameworks/3DconnexionClient.framework/Versions/A/3DconnexionClient
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswiftSpatial.dylib
/usr/lib/swift/libswiftSynchronization.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftWebKit.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswiftMapKit.dylib
/Users/rudolfneumerkel/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Karamba3D/2.2.0.161/libkaramba.dylib
/Users/rudolfneumerkel/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Karamba3D/2.2.0.161/libs/libiomp5.dylib
/Users/rudolfneumerkel/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Karamba3D/2.2.0.161/libs/libmetis.dylib
/Users/rudolfneumerkel/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Karamba3D/2.2.0.161/libs/libarpack.2.dylib
/Users/rudolfneumerkel/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Karamba3D/2.2.0.161/libs/libc++.1.dylib
/Users/rudolfneumerkel/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Karamba3D/2.2.0.161/libs/libopenblas-r1.dylib
/Users/rudolfneumerkel/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Karamba3D/2.2.0.161/libs/libgfortran.5.dylib
/Users/rudolfneumerkel/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Karamba3D/2.2.0.161/libs/libgcc_s.1.1.dylib
/Users/rudolfneumerkel/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Karamba3D/2.2.0.161/libs/libquadmath.0.dylib
/Users/rudolfneumerkel/Library/Application Support/McNeel/Rhinoceros/packages/8.0/Karamba3D/2.2.0.161/libs/libc++abi.1.dylib
/Users/rudolfneumerkel/.rhinocode/py39-rh8/libpython3.9.dylib
/Users/rudolfneumerkel/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/_heapq.cpython-39-darwin.so
/Users/rudolfneumerkel/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/_ssl.cpython-39-darwin.so
/Users/rudolfneumerkel/.rhinocode/py39-rh8/libssl.1.1.dylib
/Users/rudolfneumerkel/.rhinocode/py39-rh8/libcrypto.1.1.dylib
/Users/rudolfneumerkel/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/_socket.cpython-39-darwin.so
/Users/rudolfneumerkel/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/math.cpython-39-darwin.so
/Users/rudolfneumerkel/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/select.cpython-39-darwin.so
/Users/rudolfneumerkel/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/array.cpython-39-darwin.so
/Users/rudolfneumerkel/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/_struct.cpython-39-darwin.so
/Users/rudolfneumerkel/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/binascii.cpython-39-darwin.so
/Users/rudolfneumerkel/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/zlib.cpython-39-darwin.so
/Users/rudolfneumerkel/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/_bz2.cpython-39-darwin.so
/Users/rudolfneumerkel/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/_lzma.cpython-39-darwin.so
/Users/rudolfneumerkel/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/grp.cpython-39-darwin.so
/Users/rudolfneumerkel/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/_bisect.cpython-39-darwin.so
/Users/rudolfneumerkel/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/_random.cpython-39-darwin.so
/Users/rudolfneumerkel/.rhinocode/py39-rh8/lib/python3.9/lib-dynload/_sha512.cpython-39-darwin.so
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework "Renderer Development Kit" 8.13.24289.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp "Commands" 8.13.24289.13002
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp "Snapshots" 8.13.24289.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp "RhinoCodePlugin" 8.13.24289.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp "RDK_EtoUI" 8.13.24289.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp "MeshCommands" 8.13.24289.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp "Rhino Render" 8.13.24289.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp "RhinoCycles" 8.13.24289.13002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp "SectionTools" 8.13.24289.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp "Displacement" 8.13.24289.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp "PanelingTools" 8.13.24289.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp "IronPython" 8.13.24289.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp "Grasshopper" 8.13.24289.13002
