Small request
Can we please have a basic polygon count appear in the little dialogue box when setting the detailed/advancec mesh options?
It gives more visual feedback information, better UI/UX.
Hi Leslie - the count per object is printed at the command line if you click Preview - do you see that?
Ah yes I see that now. I only had two lines showing. It appears with three lines showing. I’ll keep it that way, with three lines from now on…
Poly count still does not appear with render mesh, but then, I suppose I should be using separate meshes anyway for detailed meshes.
Thanks very much, that is a big help.
