Feature Request: QuadRemesh - Original Poly Count
Would be a nice to have, to decide how high you will amp up the Target Quad Count
Thank you
Hi Hannes -
I couldn’t agree with you more…
RH-61846 QuadRemesh: Polygon count of input
@wim there has to be a solution of maybe showing all meshes seperately in the menu one under the other :slight_smile:
Are you aware of the ‘what’ command and Details / Object Description?
So you also expect to be able to enter different values for multiple meshes at the same time?
I would do this in Grasshopper instead…
