Hi.
I need to slice an object in two exact halves. Any suggestion?
Thanks in advance.
Hi.
Thanks in advance.
Hi Miguel,
Can you elaborate please?
What part of the slicing do you need to know about…what tools to use in Rhino or how to know what the half is.
Just tell us a little more specific about what you want to do and what it is you do not know about it.
-Willem
Hi Miguel- just a guess that maybe the CutPlane command, followed by Trim. Or is the problem actually just locating the exact halfway point?
Thanks Willem and Pascal for your help.
I am working with meshes. I have used the Align command with the VertCenter option to align both objects, and then I have used the Boolean mesh Difference to slice the main object in two parts.
This is enough for me. Any other suggestion?
