I used to use a ‘skylight’ option which created a fake but nice looking AO effect in the viewport. From memory it sat at the bottom of the Sun tab, but I can’t find it. Is it still an available command?
Thanks,
Andrew
Thanks,
Andrew
Hi Andrew,
Some renderer dont support the skylight command so make sure current renderer is Rhino Render.
Best
Jan-Ruben
Hi Jan,
I forgot about making Rhino Render active. I was set to vRay. Thank you!
Any way to adjust the Skylight intensity ? Its prob’ly there and I’m missing it.
Thanks -
C.
Hello - yes, the setting is in the environment settings for the environment that is providing the skylight; also accessible in the rendering panel.
