How to change the default size of the model parameter area on the right site of the iframe? My clients parameter text is too long so that you can’t read it. What is the correct name of the area? I didn’t find it in the documetation of the iframe settings: ShapeDiver 3D Viewer Class: ParametricViewer
Here you described the breakpoints and standard size, but not how to change it in iframe:
iFrame provides only limited customisability and it’s aimed for a quick and easy embedding. Direct embedding on the other hand is lot more flexible and allows you to build a custom UI for a smooth user experience. This code example shows you how to generate custom UI from model parameters:
