Sinusoidal point along the z-axis maintaining circular shape
hello,
basic question here: I tried several methods but none seem working.
I am trying to move points of a circle in z axis to create a regular closed sine wave in a circle shape, but after connecting a interpolate node (toggle true to periodic in interpolate node) curve will close with a straight line or in a
sinewave001.gh (21.8 KB)
irregular way, not following the sinusoidal shape.
thanks for your time
Range creates n+1 values:
you can right click on Range N input and write as Expression x-1 to get 9 steps instead of 10, which will result in 10 points
sinewave_circle_2024Feb7a.gh (9.5 KB)
P.S. Lofting the circle and sine wave works well.
sinewave_circle_2024Feb7b.gh (9.6 KB)
Actually, not so well if you look closely…
P.P.S. This fixes the lofts except alternate surface normals are flipped.
sinewave_circle_2024Feb7c.gh (16.1 KB)
So flip alternate surfaces… GH is so hard! :rofl:
sinewave_circle_2024Feb7d.gh (18.5 KB)
This is a brilliant solution. Thank you.
