Hi, I am trying to describe a sine curve with even points distribution, but as the points get more far away from the origin, they start to separate. How can I fix it?
sine_curve.gh (5.9 KB)
they are separating because you are defining the step size to be greater and greater with each evaluation of the domain. use a panel to look at what you are outputting in the SERIES component.
sine_curve.gh (9.4 KB)
Heres an updated .gh file that has equally spaced ponts along the x axis.
One doesn’t generally use both Sine and Graph Mapper. Try one or the other:
thank you Mike! it works perfectly
Thx Joseph!
