Simple swarm with field error, lines not showing up
Hi, I am following a tutorial on simple swarms with fields https://www.youtube.com/watch?v=zSI1StT07LM&t=1s
Very easy to follow, I’m having an issue at around 27:40, he adds a node where the populated geometry now turns into polylines. I have done this as well and I am unable to get the same result, additionally, the showcase of the button press in the video shows points slowly move towards the top, but mine appear for a second and disappear.
I am using a different BREP than the video as I am testing out fashion design and am unable to achieve the same look, is my brep the problem? or is there any other tutorials out there or suggestions of achieiving the swarm look in my case?
Here is the grasshopper file of mine, I have internalised the brep, if there is any issue please reply and let me know I am also quite a beginner at this.
Swarm.gh (16.7 KB)
This is how my brep currently looks at 27 minutes into the video.
Anemone and Dendro plugins are required for the tutorial I am doing, however at the point I am stuck at only anemone nodes have been used.
thank you for the help!!
