Simple Animation Video File from Explosion Assembly View in Grasshopper?
Hello all.
I have a simple assembly of 6 mesh parts that sit into each other in Rhino.
I want to make a simple explosion video where all the parts slowly move into each other using grasshopper.
How can I do this and produce a simple video file
I would like to also show the render material in rhino when possible. ( render view )
Many thanks for your help.
Ian :slight_smile:
You can create the transformations with a slider then right click the slider and click animate.
Also if you would use the search function, you’d find a ton of examples like the one linked below. YouTube has many tutorials too…
