Does anyone know why Shrink Wrap is not working properly on this mesh. Thank you
Can you upload the file?
@ftzuk sure
Rhino Test Shrink Wrap.3dm (5.7 MB)
No issues here
I get the same results, very strange
Because you are using ShrinkWrap
on a block.
This seems to be a bug. For now, you can either explode or select the block → ExtractRenderMesh
→ ShrinkWarp
yep, explode, run shrinkwrap, works
Hi -
Using ShrinkWrap
on blocks appears to work just fine.
When you run Explode
on this object and then run ShrinkWrap
, the result is as expected. The back cushions, though, are still blocks.
At any rate, there seems to be a weird combination of things going on with this object and I’ve put this on the list as RH-86423 Shrinkwrap: Failure Sample
