I found this function (ShowIsocurves) in RhinoScript help, and I am assuming it is a VBScript function? Is there a corresponding function available in Python. I want to turn on and off isocurves in a selection of objects.
Eric
Eric
I believe that function only sets the Rhino option to show isocurves or not on newly created objects - not toggle existing ones. What you are looking for is this - rs.SurfaceIsocurveDensity():
Set it to -1 to hide isocurves. If you want it to toggle, you will have to get the current state using the same method and then reset it inverted.
Thank you. I will try that out.
Eric
