Hi
Hope that someone could help!
I have used a long time ago a toolbar (I think…) that showed my latest commands used, it would update as one go along. My problem is I cant remember how I made it show under the layers panel.
Any help would be great!
Regards
Per
Right-click on the Command Line area and you’ll see a list of recently used commands.
// Rolf
Thanks Rolf
But that´s not what I mean, I used to have a toolbar that updated itself, that showed the latest commands that I used prior…
Yes that´s it, Mitch you rock, as always!!
Thanks!
Greetings,
Cannot find That MRU in Rhino 8 Option list.
I would appreciate any elucidation.
Is it possible to set the right mouse button to instead of just running the last command, instead show a list of recently used commands to choose from?
No, RMB is not configurable.
That’s too bad. I would consider holding down the right mouse button a set interval to get a quick popup of the last 10 commands to be quite a productivity booster…
PopUpPopular, may give you something close
Oh, there we go, that’s exactly what I needed, thank you!
Happy to help! It really speed things up. Maybe mark it as a “Solution”
I think you started this thread back in 2018 so you’d have to mark your own reply as a solution if that also fits (I just necroed this thread because it was the first thing that came up when I searched)… ![]()
You are so right! Thought that I already did
But now its done!
