Quick question about using AddGuide, RemoveGuide commands. I’m aware that they are only visible when SmartTrack is turned on and when you are creating some sort of geometry. Is there a way to have the guides visible even when I’m not in an active mode of a certain command? Maybe “ShowGuides” or something of that sort?
Thanks!
Hello - currently, no… see
https://mcneel.myjetbrains.com/youtrack/issue/RH-46194
Hi - I’ve added your vote to the feature request.
adding a vote to have “show guide” - hopefully it gets in Rhino 9
drawing lines to use as guides should be no more.
