Hi everyone,
I am having a trouble while trying to find accessible parcels within 500 m with shortest walk.
It does not calculates expected parcels in 500 m distance.
Any help will be appreciated
shortestwalk_bug.gh (10.2 MB)
thank you so much for your help. But I am not familiar these stream filter and value list item. I tried to do same, stream filter worked for not exploded. Is it possible to share final gh document?
I am quite sure you don’t use the component properly. Component is just a software with some basics rules. So it is pretty dumb and you use it on the border of its capacity. I will try adding some curves in order to have a better solution.
Here I added some travel from the center of the polygon to the road.
So you’ll have a better working tool.
But the length is augmented because the curve goes to the center of the cells.
shortestwalk_bug_LD.gh (10.2 MB)
