Question for people acquainted with A* pathing algorithm. Is there a way to find straight line path throught A* algorithm?
I’ ve tried two ways.
First, I make smallest number of rectangles in straight way between start and endpoint.
Second, I tried to make grid of Y-axis line to continuous line.
Thank you for your answer. It seems impossible to find the shortest path of the minimum curve through the A* algorithm. Is there any other add-on to use in grashopper?
Shortest walk is built on the basis of A* algorithm and does not find a way to the shortest path to the minimum curve.
Hello
You have 3 ways to solve your problem
Implement yourself the algorithm that is good for your problem
Find a library or another tool that can solve your problem
Change the paths in order to put more cost on turns. You can also overestimate the length of some lines.
I think it could work with changing a bit the network and adding big cost to the turns which can be 45 degrees lines
Or elevating say the curves that are horizontal. And connecting upper and lower curves with vertical lines. So you bring cost going up and down.
You could also look into Dijkstra’s algorithm or the Traveling Salesman problem, maybe they are a better fit?
Here’s an old thread of mine discussing the TSP in combination with a genetic algorithm. It’s written in Python and it should be rather straightforward to add more fitness values or weights, like discussed by @laurent_delrieu above.
Yes it is my idea for that, but as @jaesung.kim problem is like road problem, I think at the end it is quite natural to have though of this type of solution, but it will require to feed the “L” length of the ShortestPath algorithm. And length must be the time to travel, fastest on linear portion, slower on “curves”.
GHopperGIS has A* built in you can have a look at the component that does it (look at the examples that come with the plugin), it works similarly to ShortestWalk. I haven’t worked with the plugin for some time as I have been very busy (I am the developer) but I guess it should work with the latest versions.
