Shortest Path algorithm (A*Path)
Guys, I want to optimace the path from a start point to an end point. the surface is irregular and have some “obstacles” which are the “webs” (curves) that I need to avoid. I wanted to use the shortest walk plug-in, but I’m having troubles constructing an appropriate grid and how to implement the obstacles, I was thinking in a way to “took out” the points on the grid that are close or on the obstacles to then just have a “walkable” grid.
I also try with python but is hard to me. I found a lot of tutorials applied to regular python but none for grasshopper python.
0724_Pathfinding.gh (22.8 KB)
it seems there is nothing internalized in your file.
Using a graph you would just not construct the edges or flag them in a bool array as unwalkable.
Ohh i’m sorry, now is internalized
its not really accurate:
0724_Pathfinding_r.gh (17.1 KB)
Thanks anyways, I would have a look at it
Missed the part with the webs, blame the heat and the beer,hehe.
Also I am sure there is a better way, anyway, have a look at this:
0724_Pathfinding_r2.gh (20.3 KB)
Use collision component
Pathfinding2.gh (20.5 KB)
