Is there a shortcut to toggle “project object snaps” on and off, or disable temporarily (like ALT disables snaps?)
If not I wish for this. Being able to hold down a key when moving from A to B, or having a constraint like Move Vertical (M V is fast to type, so M C (for cplane) would be a great adition)
Hi @Holo
I’ve got ProjectOsnap Toggle assigned to Ctrl+p (I don’t print much and use a lefthanded mouse, so it’s easy to get to), which works inside commands.
-Jakob
Thanks both, that’s smooth!
I do think it would be nice if it was part of Rhino and I wondered if it already was, as a hidden command like join has ‘crv’ to force joining a curve from other inputs like surface edges.
Btw I use this script on a button now when I want to move something constrained:
objects = rs.GetObjects("Select objects to move",group=True,preselect=True, select=True)
if objects:
osnap = rs.ProjectOsnaps()
if not osnap:
rs.ProjectOsnaps(True)
rs.Command("!_Move")
rs.ProjectOsnaps(False)
else:
But it forces me to choose the tool in advance (which is OK of course) but I think the workflow would be even smoother if I could just hit M and then C to force it. (P would make more sence, but is further from M and the Spacebar than C is )
