Hi to all
Any hint on how to read\write a userdata and share between a C++ plugin and a dot .NET plugin ?
Can I just keep track of the UUID and order and type of the data ?
And how to manage list/arrays of data ?
thanks to All
gerry
Hi to all
thanks to All
gerry
You would need to write exported functions in your C++ plug-in that the .NET code could call or overwrite the GetPlugInObjectInterface function on your plug-in class. Can you explain a bit more about what you are doing?
Hi steve
Well i wan to make the ui of the plugin in c# since i dont want to use msvc anymore
But the math stuff in a c++ dll .
The userdata is edited trough the c# interface and used by the c++ module
I think i should expose a number of get/set routines in my c++ plugin and use them trough my c# plugin to keep everthing aligned
Gerry
Got it. So your C++ DLL is not really a plug-in, but a support library for your C# plug-in. That is a great way to go. I can help with exposing functions to C# from your C++ DLL if you want any.
This sample shows how to share data between a C++ plugin and a RhinoCommon plugin.
Hi Dale & Steve
thanks a lot , I have a clear idea on how to proceed now
cheers
gerry
