UserData defined in a dll makes a exception
Question about userdata defined in a dll
ok scenario :
I want to be able to read userdata from both a rhino plugin (rhp) and a grasshopper dll (GHA)
so I have defined a derived UserData class in a dll.
I get a exception when I call the routine (in my case a Layer object ) from the rhp plugin
UserDataEx data = new UserDataEx();
myLayer.UserData.Add(data);
Before moving the class into a dll it was working fine, so I assume the class needs something else
but since I am not a c# guru for sure I am missing something
Any info on to implement this correctly ?
gerry
Investigating a bit I think (as I said I am not a c# guru) that Rhino does not “see” the userdata
defined in the shared dll.
I have no better word to define this since I generally write c++ code
gerry
Dale Fugier , I think this is for You
If its not possible I will find a different path
gerry
I had this 6 years ago - looks like it’s still on the pile
Yep this is the same problem.
Ok so I will find a turn around
thanks
Gerry
