Share your custom viewport modes here
maybe put them on github
Yeah but it’s also not necessary to read every post in this thread. You scroll until you see a picture you like and download the files. Yes a single repository would be easier, but it’s not @Rhino_Bulgaria responsibility to spend all that time doing in. Posting on a forum is how we share information. If you want more its up to you.
Bah..some of us need work to be done..
Just browse on the phone while commuting or before sleep then just save or screenshot what you want to try when you got time is what I usually do like roight now :slightly_smiling_face:
This also exists as an app
You find the good stuff when you dig deep enough on here thats the reward there is just way to much big brain power info being shared here.
I’m going to make a winter display mode soon and you just inspired me with that photo. What country is that? Looks like Finland. :slight_smile:
OSINT ; )
Sweden near Västervik
I’m not anon no worries
I also scare people​:joy:
Thank you so much for this wonderful thread !
I needed some display mode that exposes the change in curvature while looking at extreme angles (3/4 view), so I combined two of my old display modes into a new one. The trick is to use a high contrast ring around the perimeter of the environment map to simulate reflective highlights. This is especially useful for modeling of cars, airplanes, boats and any curved product design where the goal is to focus on the highlights.
Notice the side surfaces of the airplane fuselage towards the tail, as well as the side highlight above the front air intake. The front windshield also has pronounced highlights that are completely absent in the regular Shaded view in Rhino.
Bobi XX14.rar (145.3 KB)
Bobi XX14:
Default Shaded in Rhino 7:
I already used the same approach in my “Ghosted V3” display mode posted here:
The other new display mode that I use recently is a quite simple and aims to deliver a cleaner look with low contrast.
Bobi Ultra.rar (6.4 KB)
@Rhino_Bulgaria I absolutely love this visualization, thanks for sharing it.
It’s fantastic because it shows exactly where the defect is.
Very nice looking 3d model, and the highlights seem to do their job as intended.
The goal with this particular display mode is exactly this: accentuate on the highlights and expose any curvature irregularities.
These two may be more suitable for your needs. I shifted the highlight to the top and made a mirrored copy at the bottom, so this should help with inspecting nearly flat shapes such like shoes. While "Bobi XX14 had a single highlight, there are now 2 highlights for “Bobi 15” and 3 highlights for “Bobi 16”.
Bobi 15.rar (195.3 KB)
Bobi 16.rar (245.8 KB)
Bobi 15:
Bobi 16:
@Rhino_Bulgaria I wanted to try the two materials, but you didn’t share the settings file. Bobi xx14 Anyway, I was testing them on an old car model I had modeled last year. With the 3/4 view, it highlights the areas that are in G0 and G1 really well. In fact, it was clearly showing the problematic areas where I had left the work at a stage where the surfaces were still in G0 and G1 and still needed to be refined.
Here I had fun checking where the errors were; in fact, it highlighted all the areas that still needed improvement. I think this is one of the best visualization modes available today.
Oops, seems like I forgot to include the display modes. :slight_smile: Thank you for reminding me! I just updated my post above.
I tried Bobi 15, and it looks good, but the one I consider better is 16. It highlights the surface defects more clearly. On Monday, when I’m back at the office, I’ll also test the visualization on the slipper model.
bobi 15
bobi 16
Here are the coloured versions of the environment maps, in case that you want to test them out. You just need to replace them from the settings.
Bobi 15 16 Brv.rar (368.6 KB)
P.S. I just watched your video. You may need to tune the render mesh settings, in order to make the fillets appear smoother. for example, I use these settings to export small objects for 3d printing, but you can set “Minimum distance, edge to surface” to 0,2 mm and see if this is good enough for you.
Great, I hadn’t thought about that. In fact, I couldn’t understand why, even though I was sure that in some areas — like the front section of the hood near the beginning — the surface was perfectly fine, a strange “V” shape still appeared along the symmetry line. That visual artifact was really bothering me. I increased the mesh display quality and it instantly improved with your settings. Thanks a lot for the tip.@Rhino_Bulgaria
after
I recorded a video that shows it — it’s incredible how much it improves compared to how I was viewing it before, hahaha. At minute 2:14, right after I press OK, you can clearly see the increase in mesh quality.
By the way, the file that you have opened super fast. Nice PC!
If you experience any slowdown due to the increase of the mesh density, you can go to the settings of the display mode and increase this one to 100%. That will ignore the shadows, but they will be still active. The framerate should be faster that way, but you will no longer see the gentle shadows that contribute to the perceived depth of the 3d model.
Disabling the shadows entirely also improves the framerate, but this comes at the cost of a totally different appearance of the rendered material and a very flat image, so I recommend to leave it enabled.
If you change “Density” from 1 to 0, that will reduce the mesh density (typically 4 times reduction of the polygon count, but depends on the overall shape).
Hi everyone I have collected a good amount of these display modes and environment maps and pushed them to github here GitHub - KnuckKnuck0123/rhino-display-modes: A collection of display modes for Rhino7/8 · GitHub
Feel free to download, fork, or add to it with pull requests thank you :slight_smile:
