Share your Arc / Circle construction challenges
Many times my students fight with constructing Arcs and Circles with given constraints.
This is one of those little challenges - Do you have similar ones - please share them here.
The trapped Arc
Given:
  • a horizontal Line.
  • At the start of the Line a tangential Circle with R25 (D50)
    Searched:
    An Arc with R5 (green) that is tangent to the Circle and perpendicular to the line.
    (I will post 2 solutions later, if others don’t post them earlier)
looking forward to see your solutions - and other challenges. kind regards - tom
I’d do this:
trapped_arc.3dm (162.1 KB)
As for other arc/circle issues: you should be able to find many here
… great - different to mine.
Seems to me that there are an infinite number of solutions depending on what the phrase “At the start of the Line a Circle” means.
Did you mean the center of the circle is perpendicular to the line or will any 25 unit circle that touches the end of the line do?
  • Offset circle 5 to the outside
  • Circle r5 at the intersection of the line and the offset
  • Trim what isn’t necessary (for me the fastest)
Or if you really want to draw the arc directly…
  • Arc center, start, end
  • Pick the intersection of the offset and line as center
  • With Cen Osnap, hover over the circle so center snap is active, then Tab to set direction lock
  • Come back to the r25 circle and pick the start point
  • Snap to the line to finish
This one from the 4th post is interesting:
This is my solution:
  • Circle via 2 pts to set the 5mm rad
  • Line tangent to R25 circle and intersecting with center of R5 circle
  • Rotate both circles such that the smaller circle’s center intersects with the horizontal line
Otherwise, I would have just used Pascal’s MoveToTangent script but it throws an error:
Here’s a variable GH solution based on what I posted above…
FilletCircle.gh (15.7 KB)
ok here is the collection of posted approaches - and 2 more:
draw dislocated and move
construct with mirror
construct with D30 or _offset D5
(posted by @Gijs and described by @Helvetosaur
draw dislocated and rotate
@vcruzdesigns approach
(@jim updated the initial description - sorry for being imprecise, the circle is tangent to the horizontal line)
Circle_Challenge_01_trappedArc.3dm (1.7 MB)
i like the offset d5 version, and it was among the first coming to mind as i saw your problem statement.
but there’s even the trigonometric version. SSA triangle, with S1 = 25, S2 = 25+5, A = pi/2
i think a quicker trig solution is
the distance of the d5 center from the line-circle intersection is given by:
(d25+d5) * sin ( arccos( d25 / (d25+d5) )
1 fixed Circle + 2 constrained Circles along Lines.
Big Circle with thickness tangent to the 3 circles.
I thought it was a challenge until I modelled it in Rhino…
Anyway, it would be interesting to see it with Rhino Constraints feature.
cc @Joshua_Kennedy.
ezgif.com
Moar ceerkulz!
voilà:
i came across this one today:
2 arcs are given by their Radii R15 and R35.
They form a lens-like shape.
the corners are 90 degree.
:cold_face:
(i know the solution and I am happy to post it later if nobody finds it without constraints and :kangaroo: )
a 35 x 15 triangle
:white_check_mark:
I love the smell of Autocad in the morning ; )
a new challenge - i did not find a vanilla rhino solution
Given is a circle (green) at x,y = 100,90 with R=15
The challenge is to find a circle that has its center on the y-Axis and passes the origin and will define a tangent between both circles.
This tangent has to touch the new circle at x = 20
with constraints in onshape:
this challenge is related to my other challenge regarding fillets and constraints.
have fun - cheers -tom
Radius 35.135?
No grasshopper, just a few diminishing approximations while drawing.
