I am looking to create a line tangent to an arc with an angle constraint. I can't seem to find a method of doing this without creating construction lines first.
I envision it going something like this.
enter command Line
select Tangent option
select curve for line to be tangent to
enter Angle constraint in degrees
Enter line length
I know there are other ways to accomplish this, but I am looking for a way to do this with 1 simple command and without having to create construction lines first.
Hi Brandon- so you want the line to be a certain angle off tangent, or you want it tangent to the arc but sitting at a point that is at a specific angle along the arc?
I am looking to specify an angle, lets say 45° , then create a line tangent to the arc at 45° with a given length.
Here is a screenshot of how i usually do it in AutoCad
I enter the line command, then I select tangent and then pick the arc. That is the first point. The second point is specified with “@5<45” and it draws the line.
Hmm- yeah… the @5"<"45 format does something but not the right thing - dangerously close to the right thing in some cases though, it seems to me… Right off hand, I do not see a way to do this all in one operation in Rhino.
Yes it does something close, but I cant seem to figure out a rhyme or reason why it does what it does? A couple times it ended up perfect for me, but most of the time its a little off or way off.
