Is there a way to allow end-users the ability to switch between different lighting scenes? For instance, could a user switch between multiple directional lights in order to simulate different times of day in an environment?
Thank you.
Thank you.
Light scenes dropdown is available in the lights section of scene settings and you can open the panel by clicking the pencil icon.
Moving forward the scene settings including the light set up will be available only to the model owners in the edit mode in the coming new ShapeDiver platform. However, any settings are and will be available via API and you can create UI/UX fitting to your product in a custom front end JavaScript application. See configurators our customers build for your inspiration.
