Shaded View won't change
when using shaded view on all viewports i get what looks like a background but only on perspective view and sometimes in top view. I’ve tried changing this in the display properties.
any ideas?
Can you provide some more info?
Make a screenshot and attach it to a replay here, you can paste images for the clipboard in a reply text or upload images with this icon:
What version of Rhino and Windows
If you are on V6 run the command “SystemInfo” that will bring up a text dialog
Copy and paste the text in a reply here there might be some clues as to what is wrong.
Start with making sure Rhino is up to date and your display drivers are also up to date.
-Willem
I’m using rhino 5, never had this issue before only seems with a certain batch of drawings i have received.
As you can see on the perspective view I’ve rotated it so that you can see the normal background is behind whatever background/colour has been placed.
That looks like the Ground Plane is on maybe… Go to the Ground Plane panel/tab and try turning it off?
awesome, thank you.
