Shade-Highlight selected meshes by C#
Hi all,
I am trying to check the Shade-highlight selected meshes in the Rendered view in C#:
I thought I found it, but it does not change anything:
        var displayMode = Rhino.Display.DisplayModeDescription.FindByName("Rendered");
        if (displayMode != null)
            displayMode.DisplayAttributes.MeshSpecificAttributes.HighlightMeshes = true;
Am I trying to change the wrong setting? Or is this a bug?
Thank you for your time.
  • Jordy
Try this:
  var renderedId = DisplayModeDescription.RenderedId;
  var displayMode = DisplayModeDescription.GetDisplayMode(renderedId);
  if (null == renderedId)
    return Result.Failure;
  DisplayModeDescription.UpdateDisplayMode(displayMode);
  doc.Views.Redraw();
  return Result.Success;
– Dale
Works like a charm. Thanks Dale.
Hi Dale Fugier
Does this apply in RhinoCommon?
Well, the code above uses RhinoCommon. Or am I not understanding your question?
– Dale
import Rhino
renderedId = Rhino.Display.DisplayModeDescription.RenderedId
displayMode = Rhino.Display.DisplayModeDescription.GetDisplayMode(renderedId)
Rhino.Display.DisplayModeDescription.MeshSpecificAttributes.HighlightMeshes = true
Rhino.Display.DisplayModeDescription.UpdateDisplayMode(displayMode)
I´m using Rhino 5
Hi @cristiano.pasini,
Here is a link to the RhinoCommon API for V5. You might search it to see if those features, you’ve referenced, are available.
– Dale
