SetViewFocusDistance - why no option to set it to camera target?
It makes sense that camera target would be one of the possibilities. No ?
Yes, I suppose so, and the command name suggests you should be able to enter a number or use two points to set the distance. but you cannot. I’ll get this on the pile, thanks.
RH-64604 SetViewFocusDistance - add some options 1
RH-64605 SetViewFocusDistance - add some options 2
