SetObjectDisplayMode and copying layouts
If I copy a layout, objects on that copied layout (titleblocks in my case) don’t hang on to their setObjectDisplayMode status.
Thanks,
Sam
Hi Sam - checkin it, thanks.
I see that and I also see that it is true of normal viewports as well - if you drag a docked vp far enough it becomes a floating copy and all objects revert to the vp display mode - hm - I do not know if this is specifically by design or not… I’ll make a bug track item and see what happens…
https://mcneel.myjetbrains.com/youtrack/issue/RH-41888
Hi Pascal,
in similar fashion, it would be good to have an option when creating a new floating vport to be able to match object display modes from selected source view… if possible.
thank you
–jarek
bumping this. In Rhino 8 we still have the same behavior where setObjectDisplayMode properties get lost when duplicating viewports.
