Set the base point of ordinate dimension
I cannot find a way to set the base point of some existing ordinate dimension.
When I select several ordinate dimension, the base point stop appearing and I cannot select it.
Any idea ?
Thank you!
Hello @L.H.RI ,
You can use the command PointsOn to show the control points. (Normally binded to F10)
Cheers
Hi ArchiCraig, thank you for your reply. Yes, of course, you’re right! I missed that.
However when I zoom on it sometime the point disappear, but I can still select it if I know it is here. I don’t know if the problem comes from me or if it is a common problem on Rhino.
On my end, control points only disappear when zooming intensively into it which is caused I believe by the viewport clipping and also while orbiting, there is an angle range at which the ordinate dimension disappear all together from the viewport.
If you want to get to the bottom of your display issue. I am no help on this matter :confused:
