Set multiple points - works different in Rhino 6
Hi
In Rhino 5 I could first select some points and then in Grasshopper component use “set multiple points” and selected points will be used as input.
In Rhino 6 I can not do that, I can just select points after I clicked “set multiple points”. But then if I have selected one wrong point among selected points I can not remove it from selection (input). Is it possible to select Rhino points in front of “set multiple points” or is there some other way to select points with possibility to remove some points if they were selected by mistake.
Instead of using a Point input, use a geometry input. Not very intuitive but it works. Point is specialized for points
