Set curve instead of rectangle
i was following a tutorial and did the whole coding but on a rectangle and would like to subistitute the rectangle command by the curve , how do i do that?
thanks in advance
Hello
First you need to draw a curve in Rhino if you wish is to use the Curve parameter. Then right clic on the parameter > Set one curve.
Then you’ll need to redraw the wires, or you can maintain Ctrl+Shift on your keyboard while dragging the output wires of Rectangle to the output of the curve.
yes i set the one curve from rhino . but , shouldn’t i change the rectangle command to something else? and may you please ellaborate which inputs exactly will the curve output be conneceted to?
Something like this ?
yes it did work , thank you so much
