Grasshopper set one curve after saved GH file
Hello everyone:)
I have a question on Grasshopper. I followed an introduction from my class and created a geometry tower and for the base I have chosen a rectangle and with the tool ,Curve’’ I used the command ,Set one curve’‘. When I oped now the Grasshopper file I have to create the rectangle in Rhino everytime and use the command ,set one curve’'. Does someone know what I can do so the Tower appears when I open the Grasshopper file so I don’t have to create the rectangle every single time I opend the GH file?
I am new with Rhino and GH so I’m sorry if this is a weird question…
Thank you in advance! :slight_smile:
This is how it looks when I open it new.
And I would like to see the tower directly when I open the file so I don’t have to go again and create the rectangle and use the command ,set one curve’’ when I open the GH file. Is this possible?
After set one curve, right click again and click ‘Internalise’
Thank you so much!!
Glad I was able to help. Please click the solution button so other users see this topic has been solved.
Or instead of creating the rectangle in Rhino, create it using Grasshopper.
