Separate 2 mesh bodies
I often do some things in zbrush and exporting geometry to Rhino. When I export multible objects as OBJ these enter in Rhino as one mesh I’m not able to exploge and get the objects separately. (the picture here has little polygons, I obviously can explode and joint into 2 but the reality is that I usually have more than 1mil polygons and this thechnique does not work).
Imagine I wanna do unweld of objects that are not welded but imported as logically single one.
Do you have any advise?
ps (it actually works when I export as FBX from Zbrush but I’d prefer OBJ)
SplitDisjointMesh
heard of it in the past…
works like charm (althout requires often meshrepair). Thank you @Helvetosaur
