I’m trying to create a script to automate the texture mapping of a mesh based on a surfaces coordinates, however the rhino command line always gets stuck at picking target objects, how do I send the enter key or spacebar function to the command line so that the rest of the command can be executed? I still need to set the custom mapping object in the command.
@dchristev, below seems to work. It preselects the mesh (target) before starting the command and it passes the mapping channel instead of _Enter. You can pass " Enter" instead of the map:channel as well, just put it in the same line:
def ApplyCustomMapping():
mesh_id = rs.GetObject("Select target mesh", 32, True, False)
if not mesh_id: return
srf_id = rs.GetObject("Select custom mapping surface", 8, False, False)
if not srf_id: return
# preselect the mesh
rs.SelectObject(mesh_id)
# set the mapping channel
map_channel = 1
cmd = "_ApplyCustomMapping _SelId " + str(srf_id) + " " + str(map_channel)
rs.Command(cmd, True)
if __name__=="__main__":
