ApplyPlanerMapping
Is there a way of scripting the command “ApplyPlanerMapping”? Python script if possible for Rhino 6. Alternatively, a way of doing this with RhinoScript Command Function.
Thanks,
Eric
from Rhino.Commands import *
from Rhino.DocObjects import *
from Rhino.Input import *
from Rhino.Geometry import *
from Rhino.Render import *
def RunCommand():
    rc, obj_ref = RhinoGet.GetOneObject("Select object", False, ObjectType.AnyObject)
    if rc <> Result.Success: return rc
    rhino_object = obj_ref.Object()
    tm = TextureMapping.CreatePlaneMapping(Plane.WorldXY, Interval(0,10),Interval(0,10),Interval(0,10))
    rhino_object.SetTextureMapping(1, tm)
    return Result.Success
if __name__=="__main__":
    RunCommand()
SetTextureMapping.py (547 Bytes)
Thank you Mahdiyar.
I did determine that the values in the Interval arguments are Bounding Box Values. Is there a way to control the rotation as well?
Eric
