Is there a way to use selname, selgroup, sellast as input in a command? I cannot get them to do anything except select them.
Is there a way to use them as the input points inside your commands?
Example. I make a 2 pts.
1 point at w0,1,0 Then I name it pt1
1 point at w0,4,0 Then I name it pt 2
My goal is to make a line. Luckily, there is a command, Linethroughpt. So if I select them first, I can use the command and make a line from them.
But, onto different commands.
srfpt, which makes a surface through points. Now, I would like to be able make a square surface from the 4 points.
Without clicking on them in order.
Even without a macro, in a command.
So I have 4 points names pt1, pt2, pt3, pt4 and I want to make a surface from them from selname-pt1 to selname pt-2, then from selname-pt2 to selname pt3 and so on until its done.
Even using selname interactively just using a command, is this possible? By choosing from the dropdown selname box, the starting point, then choosing from dropdown selname box pt 2 for the second point and so on…
Is there anyway to do this interactively, or in a macro. Use named objects or groups for reference points and starting points etc…?
Thank you very much.
