Is it possible to a assign a “constant” material type to an object, so that it is self-illuminating? Basically, the same self-illuminating style appears when you run CurvatureAnalysis, but with an assigned color instead of a gradient. I believe this material type is called Constant is other softwares.
Hi David- in Windows (?) Rhino, edit the material and at the bottom of the settings, uncheck ‘Enable diffuse lighting’.
Sorry, I should have said I’m using Rhino for Mac. I don’t see the Advanced settings there…
